WTT: My Type R's for your....?
Amplified No
RMS power handling (watts)
RMS power handling (watts): 750
RMS: Root Mean Square. The amount of power (watts) an amplifier can produce for an extended period.
View full glossary
RMS power handling (watts): RMS: Root Mean Square. The amount of power (watts) an amplifier can produce for an extended period.
750
Frequency response (kHz)
Frequency response (kHz): 20Hz - 100Hz
Frequency response is designed to indicate the range of frequencies a speaker will reproduce.
View full glossary
Frequency response (kHz): Frequency response is designed to indicate the range of frequencies a speaker will reproduce.
20Hz - 100Hz
Peak power handling (watts)
Peak power handling (watts): 1500
Peak power is a measure of the maximum power (watts) an amplifier can produce.
View full glossary
Peak power handling (watts): Peak power is a measure of the maximum power (watts) an amplifier can produce.
1500
Impedance per voice coil (ohms)
Impedance per voice coil (ohms): 2
Measured in ohms, this is a measure of resistance to an amplifier's power.
View full glossary
Impedance per voice coil (ohms): Measured in ohms, this is a measure of resistance to an amplifier's power.
Peak power range (watts) 800 and up
Design
Woofer cone material SoloKön™ vapor-deposit aluminum
Woofer surround material
Woofer surround material: Santoprene
The surround is a flexible ring usually made of foam or rubber that attaches the woofer cone to the frame or basket.
View full glossary
Woofer surround material: The surround is a flexible ring usually made of foam or rubber that attaches the woofer cone to the frame or basket.
Santoprene
Subwoofer size 12"
Voice coil design
Voice coil design: Dual voice coil
This is the coil of wire through which an electrical signal is sent. When the voice coil receives a charge it becomes an electromagnet and reacts with the permanent magnet found on the back of a speaker.
View full glossary
Voice coil design: This is the coil of wire through which an electrical signal is sent. When the voice coil receives a charge it becomes an electromagnet and reacts with the permanent magnet found on the back of a speaker.
Dual voice coil
Basket material
Basket material: Stamped metal
Tells you what material the speaker's frame is made from.
View full glossary
Basket material: Tells you what material the speaker's frame is made from.
Stamped metal
Subwoofer type Single subwoofer
Enclosure requirements
Mounting depth (inches) 6-11/16
Recommended enclosure type Sealed
General features
UPC 713034041443
Manufacturer's part number 08S12L72
Dimensions
Height 11.1 inches
Width 11.1 inches
Depth 6.6 inches
endofdays89
Banned
endofdays89
missouri
stillfly45
