WTT: My Old School Eclipse EA3532 4/5 Channel for a Mono
whitedragon551
Moderator
1. Product:
Eclipse EA3532 selectable 4/5 channel amp.
2. Specs:
* ChannelFlex Crossover
* Adjustable High-Pass Frequency (50–200Hz for Front)
* High-Pass Frequency (120Hz for Rear)
* Adjustable Low-Pass Frequency (50–200Hz for Subwoofer)
* High-Current, High-Speed Output Devices
* High-Efficiency, High-Energy MOSFET Power Supply
* Audiophile Grade Component Selection
* Intelligent 7-Way Discrete Protection Circuitry
Amplifier Type: Multi Channels
Bridgable: Bridgable
RMS Power at 4 Ohms: 40 W x 4 + 120 W x 1
RMS Power at 2 Ohms: 60 W x 4 + 120 W x 1
Performance
Frequency Response: 20 Hz - 20000 Hz
Signal to Noise Ratio: 105 dB
Crossover / Equalizer
Bass Boost: Without Bass Boost
Low - Pass Frequency: 50 Hz - 200 Hz
High - Pass Frequency: 50 Hz - 200 Hz
Other Features
Input Voltage: 13.8 volt
MOSFET Circuitry: Yes
Dimensions
Width: 15.75 in.
Depth: 10.82 in.
Height: 2.04 in.
Manual can be downloaded here:
Eclipse EA3532 Pg 10.
3. Description/Condition:
I described this as old school not because of age, but because of age in comparison to Eclipse's amp lineup. This was among some of the first Eclipse amps ever made.
A few small knicks here and there and a few surface scratches. This thing is in great condition for its age. Id give it a solid 9/10 physical and 10/10 mechanical.
From what I can tell its never been repaired. The warranty label was still intact when I got the amp. I broke it to make sure the insides were in one piece after I received it from USPS prior to testing.
This amp was made circa 2003 according to the manual print date.
All I can say is that this thing is very very under rated and pure SQ.
4. What you are looking for:
SQ based mono that does 500@2.
Looking for a straight trade or cash on your end. I dont have any extra funds at the moment.
5. Pictures of your item for trade:
Will sell for $130 shipped firm.
Eclipse EA3532 pictures by whitedragon5515 - Photobucket
Not going to lie it atleast does 200. I did a comparison with my XA5000 @2 ohms. Same exact everything right down to the song and gain settings and the EA3532 was louder at 2 ohms than the XA5000. The XA5000 is rated at 420@2, but is under rated. The EA3532 is rated for 120@2.
whitedragon551
Moderator
whitedragon551
IL
whitedragon551
