WTT 2 Channel Amps!
snoop3111
1. Product: MTX 91002 and Boston Audio GT275
2. Specs:
MTX 91002:
# of Channels 2
Minimum Single Channel Impedance 1
Class A/B
Amp Type Full Range
Power Supply Semi Unregulated MOSFET
THD + Noise (1 Watt) 0.1%
Signal-To-Noise Ratio (1 Watt)71 dB
Overload Protection
Thermal Protection
Xtant Technology Cooling
Continuously Variable Fan Speed
Connection Terminals
StreetWires Connectors
14.4VDC Power
4 Ω 250W x 2
2 Ω 500W x 2
1 Ω 750W x 2
4 Bridged 1000W
2 Bridged 1500W
INPUT (RCA Connection)
Low Level x
Hi Level w/ Smart Engage
Input Sense 100mV-1V/1V-10V
GAIN CONTROL Individual - 100mV-10V
CROSSOVER Hi,12dB / Low, 24dB Mono @ 40Hz-350Hz, Defeat
SubSonic @ 30Hz, 12dB/oct, Defeat
EQUALIZATION Parametric: Boost/Cut +/-12dB, Freq. 30Hz-80Hz, Q 0.5-4.0
ARC: Cut 0-15dB, Freq. 200Hz
OTHER FEATURES Remote Subwoofer Level Control Parallelable
ByPass Features
DIMENSIONS
Width 24-11/16"
Depth 9-5/8"
Height 2-1/2"
Boston GT275:
2-channel car amplifier
75 watts RMS x 2 at 4 ohms (120 watts RMS x 2 at 2 ohms)
1-ohm stable in stereo mode (150 watts RMS x 2 at 1 ohm)
225 watts RMS x 1 bridged output at 4 ohms (300 watts RMS x 1 at 2 ohms)
CEA-2006 compliant
variable high-pass filter (20-350 Hz, 12 dB/octave)
variable low-pass filter (50-350 Hz, 12/24 dB/octave)
Q-Tune technology for crossover adjustment
cooling fan
frequency response: 10-95K Hz
preamp-level inputs
fuse rating: 30A x 1
4G power and ground
adjustable mounting feet
8-3/4"W x 2-3/8"H x 9"D
3. Description/Condition:
MTX 91002:
I bought this amp off of somebody locally almost a year ago and was used to power 2 Type R's, gave me a demo and never saw below 12.8V. I have recently tested it to confirm it still works. Also the allen key screws for power and ground are missing but I will get new screws for them upon request.
Mechanically: 9/10 (used)
Cosmetically: 7/10 (Few small scratches also missing screws)
Boston GT275:
This amp is LBNIB. I bought this amp brand new. I opened it and have had it sitting around since. Never used it because plans had changed. I have not powered it but will upon request.
Mechanically: 10/10
Cosmetically: 10/10
4. What you are looking for: :
Looking specifically for a beefy 8 or 10 that takes around 1.5-2k, Also looking for a solid 4 channel that does 100-150 @ 2 ohms. But I am open to really anything car audio related
5. Pictures of your item for trade:
Text me anytime for more info/pics at 5857461905
Maybe, im good on wire and terminals for now but I do need a router //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
Dang, all I got is wire and things no tools, you don't need any distros, fuse holders, batt terms etc?
snoop3111
snoop3111
Rochester, NY
snoop3111
BP1Fanatic
BP1Fanatic
