honestly, this is so frustrating and it feels like i just wasted so much money on this ****. i just want a working fcuking system again. it just makes me want to scrap my whole car buy a new one and start completly the hell over. //content.invisioncic.com/y282845/emoticons/crying.gif.ec0ebefe590df0251476573bc49e46d8.gifThat's a really strange problem, not sure I've heard of anything like that before....
will do. is there anyway to check rcas with a dmm as well? this is just frustrating because all the stuff is under warranty nd i dont know which is the problem. by the time i figure it out, everything will be out of warranty.try reverseing the rca, if the louder channel switches sides its NOT the speakers.
Bad RCAs can't cause this problem. Thnk about it, you're getting that power from the amp. That means that the problem is downrange from the amp. I has to be either the speakers, the crossover, or the install.left channel: 30 volts which is equal to 300 watts
right channel: 22 volts which is equal to 161 watts
well ichecked my install and everything seems fine. all the wires are good and everything is wired correctly. speakers are mounted firmly and all that. now you say, its either the crossovers or the speakers.Bad RCAs can't cause this problem. Thnk about it, you're getting that power from the amp. That means that the problem is downrange from the amp. I has to be either the speakers, the crossover, or the install.
That tells you the Re of the total load, not the impedance characteristics. Nor does it tell you if there is a bad component in the crossover. Try this to see what I mean. Disconnect either the woofer or the tweet from the crossover and test it as above. You'll probably get the same value or really close to it.i checked my load going from the speakers+crossovers+tweeters to the amp (actually from the amp, but whatever). ipulled the wires from the amp and checked the left channel and i get 3.3ohms, and then i check the right channel and get 3.3ohms...this would suggest the speakers and crossovers are good no??
