Wrong turn!!!!!!
ya about that do you think it would be better series or how it is? my first thought was that tha parrallel wiring was to much for the amp. but i guess not
A pair of Dual 4 Ohm subs wired parallel/parallel will yield a 1 Ohm load (safe for that amp - rated output being 1.6kW at that load)
At that load your Zeus is rated to feed 800 watts apiece to each sub which should suit them just fine. Wired any other way and you'll decrease the output to each sub.
sorta. they move soso. not to much but not to little. when it gets distortied ya i belive they do move more.
switch the + and - on one of your woofs...
I'd bet your woofs are out of phase.
Outside of that, your probably expecting too much out of the setup //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
ok thnx. it just sounded to my like my old setup was sounding louder. which + and- do i switch? also would these subs sound better in my car or in an ford expedition? cause those things rattle the hell outa it.
the + and the - for the sub period, leave the coils alone.
search, Im sure there are 100's of "out of phase' threads.
Ben_Davis
Ben_Davis
Mesquite,Nv
Spkrman
