Wrong turn!!!!!!
thnx for reply
my power comes directly from my battery to a distribution block. my ground is in my trunk by where my spare tire is. i drilled my own hole and sanded it. . my rcas are ran under my carpet to the back. my subs are wired in parrallel. anything else?
Voice coil config(is this like dual voice coil 4 ohm?) this is in a 1992 nissan sentra
yup, thats right
So are you saying when you turn the gain up a little bit, the amp goes into protect?
That amp is one ohm stable, isnt it? Are you sure the subs are working/hooked up //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif?
have you checked the amps fuse?
no when i turn up my gain past a certain point the protect light blinks. doesnt turn off or anything it blinks. and ya im pretty sure my subs are hooked up right. +2+2 amp -2-2 amp. also will a ported box work better?
i doubt electrical system is the problem here..
Something is wrong with the setup.
More important than the gain level on the amp, what volume do you have the head unit at when you are "barely" turning up the gain?
iirc they only come single 4 and dual 4
Thanks for the info, bimma. I been skooled by the Bimma! //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
So which are yours, Ben? And as for a ported box I don't think that the enclosure type has anything to do with what you've describeds to us. When you originally said overhead light the first thing I thought of was that the dome light was coming on when the amp got cranked, hence my questions about your wiring. Something certainly sounds amiss...
i forgot to give this one detail. could it be cause i dont have an hu? im running it off my psp cause my hu is being repaired. stupid me:crazy:
Ben_Davis
Ben_Davis
Mesquite,Nv
Spkrman
