Would You Use This For Speaker Wire?
WOULD YOU USE THIS WIRE
  • Total voters
2fnloud
Know Y U belive what U do
I have been collecting pieces for my next install. It is going to be a 5.1 DTS setup and I am doing a 3-way active crossover set up in the front and a 2-way active crossover setup in the rear. I will be running my center with the supplied crossover supplied with the components. This is going to require 14 runs of speaker wire.//content.invisioncic.com/y282845/emoticons/eek.gif.771b7a90cf45cabdc554ff1121c21c4a.gif I am currently planning on using the Monster 402 XLN XTREME SUBWOOFER CABLE For my subwoofers And Monster 402 XLN XTREME SPEAKER CABLE for the 8" in my 3-way set up. I was even thinking of using the Monster brand speakercable for EVERYTHING but that stuff is thick and with needing to do 10 runs to the front of the car that bundle would be as thick as my wrists. than I stumbled upon this:
http://http://www.monstercable.com/productdisplay.asp?pin=85
Now it doesn't say what gauge the wire is but has an O.D. of 10.9mm and that is 2.4mm larger than this.
http://http://www.monstercable.com/productdisplay.asp?pin=1333
and that product is listed as 14GA so I would guess that the first product being a larger O.D. MIGHT be 12GA. I know this stuff is meant for house but can anyone forsee a reason that it couldn't be used in car. Any insightful input would be awesome. Because this would cut my number of runs down to five.
OK now that I have opinions. Let us stick to the poll. Would this wire pick up any unwanted signal noise. But if you must know I won the subwoofer cable and speaker cable in a CarDomain contest. And I would put my Micro XLN RCA's up against most anything. And giving that I was able to buy a 6-channel Monster Micro XLN at 5 meters in length for 22.00 shipped to my house....I don't think that was a waste of money.
2fnloud
2fnloud
Ithaca, Michigan
2fnloud
