Would it be better?
i think you should lower your sub a bit.. corect me if i'm wrong?
and if you have to CRANK your system for it to become loud, make sure everything is connected securely and installation is good //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
Originally posted by Free_Style MB Quarts componets are set at about 150hz and sub is set at about 110hz is that what it should be. Can you use a voltmeter to test HZ.
It seems like i have to crank the system so the speakers sound good.
No you can't use a volt meter. I would suggest checking, and adjusting your gains first. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Free_Style
Free_Style
Chicago
ramos
