would i get the most output from my sub ?
bren
I'm wanting to run a pioneer tsw304r in a 2.0 cubic feet ported enclosure with 1 round port 2inches wide and 2.67 inches long tuned to 32 hertz going to give me the most output from my sub ill be running a 1000 watt crunch ground ponder amp to power it? port length calculator gave me measurements for the port size based on size of box and hertz i was wanting to tune it
Good question. Some of those port calculators are more for home audio or lower end subs. With your pioneer,that amp and box will work nicely,but you will need to use a 4 inch diameter port to avoid port noise, or wind comes out of the port instead of bass. To get "the most" out of you sub, use a 4 inch round port 9 inches long. Will tune to 38 hz. Nice simple setup that should be pretty loud for daily beating. Good luck.
also its going to be in a single cab s10 top depth of the box can be 5 inches on the outer diameter and bottom can i was thinking about having port come out the top of the box but could i make the port fire out the side of the bottom ?
bren
bren
greenfield ohio
bren
