would i get port noise with these dimentions?!
  • 5
Psyence
Customized
447
Canada
I have a single 12" type r
im building a box, again //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
if i have 2 - 2x6" slot type ports, would i get port noise?
NO!
These guys obviously don't know how to design boxes //content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif
24 square inches of port area will be plenty.
NO!
Depends on the internal volume of the enclosure . For a 1.5 cube box it'll be fine., but for more cubes you can count on having port noise at high volumes. For an SQL enclosure, go with 17sq.in. of vent for every cubic foot of internal air space. ALWAYS sounds great and NEVER has noise!
It's a 2ft^3 IIRC on his past posts. And the drivers specs determine how much vent area is required. You can't just use a givin number like 17 square inches...
Yeah, saw that too, was like ??? wtf! They do know there stuff, I usually just roll with it!
13
996
You could try to make the port longer, but there might be other reasons with the box won't extend lower, or even the sub. You'd have to reverse...
694
While that program is pretty neat, it assumes you know the values. I was just recapping the numbers you provided. RS recommends the following...
867
837
Yup. That is the bread truck that Richard Clark built for MTX many years ago . 60 inch subwoofer. The problem was that the truck wasn’t...
14
Psyence
Customized
Psyence
Canada
tRiGgEr
    May 16, 2024
    May 16, 2024
