Wood thickness?
3/4" MDF is most commonly used. the 5/8" MDF is good for under 1kw systems. You will still need bracing on the inside of the box no matter what thickness you choose. you can double up on the baffle to help with flexing also.
would you say .5 is to thin?
how many watts, how many speakers ,what size box
it would be 2 Boston Acoustic G5 off of 500 Watts Each. so the enclosure would need to be 2.0-2.4ish
would be somthing of this sort.
Also how much room is needed between the sub mag and the wood?
On a box like that, I would say 1/2" material would be ok. The panels are relatively small in size. If you use 1/2", just be sure to properly brace it and I bet you will be just fine.
BJ! Where've you been? //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
I miss seeing your builds.
BJ! Where've you been? //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gifI miss seeing your builds.
I have been swamped with builds lately. Not posting here too much, as I only post my builds here for members. I have had a couple builds going on here lately though. All my other builds are up over at SSA.
Cali_Screw
Cali_Screw
Rancho,CA
bjfish11
