witch will have better sq and go loudest of the 2
I'm not sure I would even do one 12 in that space. I have my Q 15 in 3.65cu and it pounds! No way I would even waste my time and money sticking on in that size box
when thats all you got to work with, thats all you got,
the FiQ say 2-2.6cuft sealed, i able to get a bit more space but ill have to build/screw and clue inside car and ill be around 2.2
but that will be a bid harder for ported 10" to do that when box will be jammed up against 5 wall,(backseat,sidewalls, floor and parcel shelf)
fiQ 10 recommend 0.5-1.2cuft ported
when thats all you got to work with, thats all you got,the FiQ say 2-2.6cuft sealed, i able to get a bit more space but ill have to build/screw and clue inside car and ill be around 2.2
Ya meaning you dont even have for a single 15 sealed let alone ported and you only have room for 1 ten ported not 3...
just went and double checked all the measurements and if i go sealed i can build 2.6cuft
so 2.35cuft if i use 1 FiQ15" sealed (fi rec 2-2.6)
or i could even do 2 12" sealed in 1.1 each separate chambers (fi rec 0.8-1.5)
if i build ported i can only build 2cuft
2cuft-0.36 for sub and 2x12"aero ports@0.03ea=1.6cuft for 3 or 0.53 ea@30hz (fi rec 0.5-1.2)
either way i paying through my a$$ for freight and there still cheaper then the bottom line kickers or jl over here, thats why i need to get it right
from Fi the a single q 15 at my door with cooling and spider upgrade is $936us so after import tax and exchange rate im around $1150us or $1100au
as you see it something i want to get right
which witch is which?
seriously though, I tried a 12" in a 1cf sealed box once... did not sound good, got a 12" in a 2.6cf ported, much happier.
I'd probably just go with a 10" in your position.
john253a
john253a
Austuralia
john253a
