SSA Icon vs Fi Q
helotr3vor
Maybe you guys can help me decide witch sub would be better for a shallow mount. My box dimensions are 35x12x16in with the baffle on 35x16. There is most likely going to be a port behind the sub witch would make it displaced even more shallow. The box is going to be tuned at 32hz for one 12 Icon or Q. Which sub do you think will perform better for this box? Should I go Aeroport instead?
The Q has a High Qts and low Qts option, so you can custom order it to sealed or ported enclosures respectively. Both are excellent performers, and neither need pole vent clearance due to not having one. //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
Do the new Q's not have a pole vent?
I know I can't go wrong with either one but I was hoping the box dimensions would help me decide a little bit. I don't understand the pole vent you guys are talking about can someone explain what it does please.
By that they mean the sub dosnt need any room behind the magnet to breath. Some subs have a hole in the back of the magnet with which air flows threw hints the term "vent".
Either sub will be a good choice //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif But ide DEFF go with an precision port over any other port(or just a flared port kit of some kind)
helotr3vor
helotr3vor
Irvine, CA
tc300
