wiring xbox into car
okay so today i finally got around to wiring the inverter directly to the battery and i grounded it behind the rear panel, but i still get the buzzing in the speakers and faint lines going thru the screen. Anyone know a way to fix this? Would a loose ground, or maybe i didnt sand thru the paint/primer enough under the ground?
Your not going to fix it unless you spend a lot of dough on a true sine wave inverter. The cheap ones are modified sine wave and you will likely get interference like you are experiencing.
Good lord that is a lot of dough!//content.invisioncic.com/y282845/emoticons/eek.gif.771b7a90cf45cabdc554ff1121c21c4a.gif Just keep it the way it is i guess.
tacobandit
tacobandit
LA, Ca
tacobandit
michigan born
    May 14, 2026
michigan born
    May 14, 2026
