straightshot7
Ok I want to upgrade my stereo in a 2006 Honda civic ex coupe with the factory premium 7 speaker stereo without navi. I want to keep the stock deck but want to upgrade stereo I'm thinking at first just using the factory amp to run the miss and highs and just upgrading the speakers temporary then adding a 4 channel later but I want to go ahead and add a sub amp with factory amp now I'm considering buying a Audiocontrol lc7i to integrate it all instead of a cheap loc now I'm needing help with how to wire this up? Should I just use the sub output wire from the factory amp to use on lc7i high level input to just run the sub amp? Then with a 4 channel amp would I have to bypass the factory amp or could I just leave it hooked up from deck then use the mids and high output wires out of factory amp to lc7i? I will eventually run new speaker wire for 4 channel Please help
