Wiring Two Amps Questions
Boyers19
I have a mono block amp connected to my sub and i just got a 4 channel amp for my front and rear speakers. i have a few questions...
Should i get a power block to split the power cables between the two amps?
Should i get a ground block for the same thing?
And then the tricky part is how do i make it so the amp turn-on wire gets to both amps with only one cable from the HU?
Thanks for the help, im just getting into car audio and im really interested in it!
for the power wire it depend how much power you are running with the length and wire size you have
for you ground on your amps just do individual lines going to bare metal on your cab
the line that terns on your amp is called the remote wire and that you can just run a wire from the one amp to the other with no problems
Boyers19
Boyers19
United States
nathans.sound
