Wiring Troubles. Need Help.
Mx3guy
Ok im hooking up my system and i keep blowing fuses. This is what i have:
4 gauge Power wire.
140 amp anl fuse.
going to a 2 farad cap.
2 (one to each amp) eight gauge power wires to the amps from the cap.
Then the ground wire of the amps back to the cap.
Then the cap grounded with a 4 gauge wire.
The wire is industrial grade and is said to withstand over 150 amps. The amps are orion one is a 600d and the other is a 8004.
The problem is I blew the 140 amp fuse right off the bat. the amps shouldnt be drawing the much because their gains are turned down a little.
I was wandering if the cap caused it to draw more amps?
What do I need to do to get this to work?
Thanks for the help.
Mx3guy
Mx3guy
Oklahoma
Mx3guy
