Wiring to 1-ohm
whitedragon551
Moderator
Im wondering if I did it right. I have speaker wire on both VCs. Gold is positive silver is negative. I took the gold from each side and twisted them together and put them on the positive for the amp and same thing for the silver except its in the negative. Did I do it right?
JL audio has a good diagram of hooking up subs, talks about svc and dvc along with ohms. go to JL website then click support tab, then choose subs and enclosures then go from there.
Shows that the positives are wired together and then to the amp and same for negatives or am I thinking wrong and it really means how I did it above.
But I think coming from amp that wire needs to go to VC1, then from VC1 take additional wire to VC2. So the VC1 pos and neg should have two wires going to it.
Just run a speaker wire from each coil's terminal of the sub to the pos/neg terminals of the amp (whichever that terminal on the sub is, run it to the same terminal on the amp) and it'll be 1 ohm.
So you'd have:
-2 runs of speaker wire on the amp's positive terminal, each going to a positive terminal on the sub
-2 runs of speaker wire on the amp's negative terminal, each going to a negative terminal on the sub
Thats how it is saturn. I have pictures. The way it was when I picked it up was 2 sets of wires. Each set had a positive and negative. I took the positives and wired them to the positive on the amp and negatives to the negative on the amp.
The way the diagrams show is the positive runs to a positive and then a positive to the amp and same for negatives. Are both ways correct?
whitedragon551
Moderator
whitedragon551
IL
whitedragon551
ThxOne
    May 13, 2026
ThxOne
    May 13, 2026
