Wiring stock HU to sub and amp
go to a local audio store or best buy or something. You want to get a line-out converter. This will have 2 sets of speaker wire which is usually best to hook up to the rear speakers. That way you can fade it to the front if you ever wanna turn ur sub down. You can do this behind the radio if you want to have ur rca's up there, or you can tap into your rear speakers(if there accessible)from your trunk. pretty easy to do if you have some exposed 6x9s or something in your trunk.
Then again not sure what kind of vehicle you have.
Either way grab a line out converter and that will transfer speaker wire input into rca output. Grab some self tappers from a hardware store or if you already have them to get a good connection.
Using a line out converter on the rear speaker wire, will this mean I will then need a crossover so no high frequencies reach my sub.
if you have a mono amp, it should have a LPF built in. this may not be the case for all amps though. what amp?
The wiring harness adapter is less than $10 online. It makes everything 10x easier. You just wire your new stereo to the adapter outside of the...
189
Ive doubled up 12 ga many times for sub wiring.. even 14 ga for speaker wiring. Its OFC and it should do great and save you some money since you...
598
My brain hurts just looking at those diagrams. It's late so if anyone sees a problem with either of those, please feel free to chime in!
638
646
waterstone
waterstone
los angeles, CA
jco1385
