Wiring SPDT On-Off-On with Relays
  • 2
Bdowdy07
This is probably a very simple task but I cannot seem to figure it out. I built a radio cooler that has a SPDT On-Off-On switch and would like to achieve the following.
Switch position one - Radio only
Switch position two - Radio, Usb charger and led lights
Switch off - No current draw
What would be the best relays and configuration to achieve this?
You can wire the Radio through one switch leg and the Radio, USB, and LED through the other switch leg.  A On-Off-On switch has a center common for the hot conductor.  Then you'll have the Radio power to both positions one and two.  USB and LED will only be wired to position two.
You could also use relays.  You can dedicate one relay to Radio with a second relay powering Radio, USB, and LED.  In that configuration the On-Off-On switch would power the relay coils.  This allows you to use a smaller toggle switch since it won't see the current of the load.
While both corrode, CCA will corroded 10x faster, and carry less current. Knuconceptz kollosus is cheap enough to do it right the first time
47
177
Box rise, more accurately, impedance rise, is the reactive load changes the woofer exhibits at different frequencies and it will happen, it's...
425
thanks 1aespinoza for advice I decided to not use the blaupunk I got a real nice Pioneer.
338
Bdowdy07
Bdowdy07
keep_hope_alive
