Wiring question
You will not have definite problems. wiring subs like that will require a multi-meter to level set each channel to the same output. I am not going to explain it here how to do it, but I'm sure you can find how to do that on this site, or on the12volt.com. Using a higher qua;ity amp is always recommended when running different channels/amps to the same sub, and your PPI is a decent option to do this, which is very possible. I've run an amp to each coil W/O issue, just be sure the levels are even.
billjones42
I shot the sheriff
billjones42
Minnesota
Dr. Hertz
