Wiring Problems
  • 4
zimmer82
Wiring Set Up
I have an Orion P-series, dual 2 ohm, that will be hooked up to my orion 600d at 1ohm. My question is....On the subwoofer, when you connect the two voice coil positives up, is that a whole separate wire then the woofer-to-amp wire?
Also, are those wires the speaker wire or is it some other wire? Do i need 4 separate wires or just two?
Sorry, but it may be my first system that i wire up myself.
Thanx in advance
One wire will go from + of one VC to + on another VC; - of one VC to - of another VC; then one wire from + of one VC goes to the amp, then one wire from the OTHER VC goes from - of that coil to - on the amp. Simple... look at the wiring guide.
so i would need four separate wires right? one to go from + on vc1 to + on vc2, then another wire from vc1 or vc2 + to + on amp, then same for the negatives?
Based off GM pickups of the same year (and that was GM), It SHOULD just be for the vehicle sounds that play through your stereo, such as the door...
Ive doubled up 12 ga many times for sub wiring.. even 14 ga for speaker wiring. Its OFC and it should do great and save you some money since you...
211
My brain hurts just looking at those diagrams. It's late so if anyone sees a problem with either of those, please feel free to chime in!
277
456
411
zimmer82
zimmer82
Lafayette,Louisiana
zimmer82
    May 23, 2024
    May 22, 2024
