Wiring Problems
zimmer82
Wiring Set Up
I have an Orion P-series, dual 2 ohm, that will be hooked up to my orion 600d at 1ohm. My question is....On the subwoofer, when you connect the two voice coil positives up, is that a whole separate wire then the woofer-to-amp wire?
Also, are those wires the speaker wire or is it some other wire? Do i need 4 separate wires or just two?
Sorry, but it may be my first system that i wire up myself.
Thanx in advance
One wire will go from + of one VC to + on another VC; - of one VC to - of another VC; then one wire from + of one VC goes to the amp, then one wire from the OTHER VC goes from - of that coil to - on the amp. Simple... look at the wiring guide.
zimmer82
zimmer82
Lafayette,Louisiana
zimmer82
