Wiring Problem!!
SOUNDSTREAM-LNP
g'day i have a CDX-CA900 Sony Xpold HU, Soundstream 2 Lil Wonder 4 amps, 2 Soundstream Rubicon 12"s SVC and a Soundstream SPL 15" DVC and Soundstream 6"SLP G Splits now i don't really understand how to hook the RCA's up to run the 2 amps, i want the HU to turn on the amps how can i do this to split the REM cable into 2 for both amps, also i don't know what power cable or speaker cable but i want all this to run at full cap...alsoo would it be better to use a fuse at the battery and a fuse dis box at either end to make sure nothing happens and should i use a Dis Bos for the postive and negive???
can any1 give me any clues??
well on the remote wire just split the wire .....shouldnt hurt anything since your only using 2 amps but if u wanna be on the safe side....get a relay and wire it in.....
and im not sure what u mean u want the wire to run at full cap????
and for the fuses...put one w/in 12inches of the batt and fuses at the distribution block......and only use the dist. block on the power wire
actually you would want to use a relay to power the amps. the remote turn ons on head units fry easily if you try to pull too many amps through it.
and you would want to put a fuse about 12 inches from the battery, and if you use a distro box, fuse each distributed power cable. You want to use a fuse everytime you go to a smaller wire. -scott
Ive doubled up 12 ga many times for sub wiring.. even 14 ga for speaker wiring. Its OFC and it should do great and save you some money since you...
411
My brain hurts just looking at those diagrams. It's late so if anyone sees a problem with either of those, please feel free to chime in!
485
545
487
SOUNDSTREAM-LNP
SOUNDSTREAM-LNP
australia
fantomas
    May 31, 2024
    May 24, 2024
