Wiring problem...i think
  • 2
Lewbrah485
hello, i've been installing my system w/ a friend of mine and we got everything hooked up and when we went to turn on the subs, nothing happened. we checked the wires and we are 99.9999 % sure that its right. The only thing is that a fuse keeps blowing for the panel lights where the speedomintor etc. is. I replaced it and it blew again. At first we thought that my amp was just a bad amp and i needed to be sent a new one but now we are thinking its a wiring problem. Any help will be greatly appreciated!! THanx
I had the same problem at one point. I found out after hours of messing with it that my fuse was shot as well. So I went and got a circuit breaker, which works perfectly.
The wiring harness adapter is less than $10 online. It makes everything 10x easier. You just wire your new stereo to the adapter outside of the...
189
Ive doubled up 12 ga many times for sub wiring.. even 14 ga for speaker wiring. Its OFC and it should do great and save you some money since you...
598
My brain hurts just looking at those diagrams. It's late so if anyone sees a problem with either of those, please feel free to chime in!
638
646
555
Lewbrah485
Lewbrah485
Pittsburgh, PA
EarDrummin.
