wiring multiple speakers
ok never mind if i wire 8 up like that, itll make a 1 ohm load.
what would mids sound like if i got a 1 ohm stable 1 ch. amp for all 8? like 800w rms @ 1 ohm, and each of those mids would get 100w.
So basically if I hooked both left and right door speakers to 1 channel on a 2 channel amp I've got laying around, it would give me an idea of what a mono amp would sound like if I used one? (Being as I'm using 1 channel for both sides?)
I've never understood the whole 8 speaker thing, but hey, whatever floats your boat, good luck. And yes, if you hooked them all up to 1 chan. of a 2 ch. amp without bridging it you get a mono signal.
ok i tried it and it does sound like *** so i found the 2 channel amps im gonna get...
think the MA HK 2 ch amps can handle 1.6 ohm (theyre rated @ 2 ohm stable) the way the speakers are gonna be wired makes a 1.6 ohm load for each channel.
pimpedout97x
Tampa, FL
pimpedout97x
