wiring jbl 1200.1
  • Thread starter steadyru
  • Start date
  • Replies 5
  • Views 692
S
steadyru
Guest
I have a jbl 1200.1 and 2 jl audio 12w3-d2's. I want to wire them to produce a 2 ohm load. The amp has two outputs. So how would I wire both the subs? Btw does anyone know about the speaker level inputs on these amps? Does using them decrease the quality compare to having RCA's?
use rca's when you can the sound quality is much better if you have a high pre-amp output, and puts less work in the direction of the amp .....as for your speakers are the 4 ohm voice coils, and I believe they are dual voice coil......Is this correct
if your subs are dvcs wire them down to 2ohm and one to the first channel of the amp and the second sub to the other that way you get your 1200rms per channal these amps are not bridgeable so you cant get a one ohm load for 2 speakers the amp is just one ohm stable 4 4ohmsubs two each side,6 8 ohm subs 3 on each side or two 2 ohm subs
Ive doubled up 12 ga many times for sub wiring.. even 14 ga for speaker wiring. Its OFC and it should do great and save you some money since you...
280
My brain hurts just looking at those diagrams. It's late so if anyone sees a problem with either of those, please feel free to chime in!
362
485
436
Guest
    May 24, 2024
