Wiring in parallel/series?
  • 5
series makes a higher ohm level therefore decreasing the power out of the amp. Paralell drops the ohm rating in half so the power is usually doubled.I could be wrong and i'm sure mmray or rangerman or zane will crrect me if so but parallel is the best way to got for bass and series is for SQ.
J
lower impedence= less dampening usually ..............higher impedence = more dampening dampening=control lower impedence usually.= more power .............................
Originally posted by audiolife lower impedence= less dampening usually ..............higher impedence = more dampening dampening=control lower impedence usually.= more power .............................
This is exactly true!!!//content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
I dont get it??? //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
take it easy,
-zane
The wiring harness adapter is less than $10 online. It makes everything 10x easier. You just wire your new stereo to the adapter outside of the...
186
Ive doubled up 12 ga many times for sub wiring.. even 14 ga for speaker wiring. Its OFC and it should do great and save you some money since you...
587
My brain hurts just looking at those diagrams. It's late so if anyone sees a problem with either of those, please feel free to chime in!
626
641
supra_mkiii
supra_mkiii
Joliet, IL
audiolife
