Wiring help!
Cody13x
I have a dodge Dakota, I'm installing a single duel brand 12" with a 400watt duel amp ( both brand new). I have a 670 watt max wiring kit. The hot wire is installed correctly, along with the RCA cables to the head unit. Ground wire is screwed to the floor, through a cut in the carpet and a self tap screw to hold the wire down to the cab. The remote wire had to be connected to the fuse box via an Add-a-fuse adaptor, in the cig lighter fuse slot (20amp). The problem is that the amp won't turn on (I believe the remote wire is the issue). I'm stuck, any help?
rub some cocaine on the remote wire //content.invisioncic.com/y282845/emoticons/up2something.gif.dd110ecf3ae4b76050d87598f2f8de7c.gif
use a digital multi meter and place the ground wire on just a ground and then place the positive wire in your fuse panel on an empty fuse slot there is two sides its the top and turn your key on acc do not turn the car on. if you get a reading of 12+ volts when you turn your key and then turn it off then thats the one you want to put ur remote wire on. do this and see if your amp turns on. on another note just buy the sounds of it, it doesnt sound like you have a good ground. take a pic of your install so we can see better. also get some new audio and learn to read, YOU PUT THIS IN THE WRONG SECTION........... FAIL!
//content.invisioncic.com/y282845/emoticons/popcorn.gif.32dd9e22fd77e77bc3c907062768fcd2.gif
*nudge*
Gimme a handfulla dat.... //content.invisioncic.com/y282845/emoticons/suave.gif.858fc102f7646e678ee8af7e1fbc41d1.gif
Thanks for the input. Much appreciated. The dsp is an afterthought. I haven't installed anything yet but I put a budget system together. I already...
613
In a case like In a case like yours I would rather recommend tactile transducers. They are like woofers without the cone section that are...
975
Your image doesn't really show anything. That could be 3 different head units for all we know, but I think it's 2 different add-ons. It sounds...
Try again on the attachments/pictures. They didn't load. Not exactly sure on the wiring, but you can buy an adapter harness that goes from your...
Cody13x
Cody13x
Lake Ariel, PA
goingdef
    May 24, 2024
    May 23, 2024
