Wiring help
sickofsoyo
DO WORK SON!
I am planning on putting 2 sets of JBL C608GTI component speakers powered by JBL PX600.2 Amps. The RMS on the speakers is 150 W @ 4 ohms, which these amps provide, with a Max of 600 watts. The amps provide 150 W @ 4 ohm into 2 channel RMS, with max power rating at 1200 Watts. My question is how am I going to wire this setup? I need a distribution block, but what guage wiring and what else? Do I need anything else to make this work? The car is a 2003 Monte Carlo SS.
Attached is a quickly drawn diagram of what Im looking for, so maybe if someone can copy it, and edit in what I need and where, it will help me more.
Yes I know the battery is further up than where I put it on the image
Are your amps really one in front & one in back? if they fit under the seat, do them both up there. Otherwise I'd do both in the trunk.
Run a single 4g to a distro block, then 8 g to each amp - that's all you'll need. (2) 8g grounds to the same spot in the trunk. 16g speaker wire should be fine but 14g would be better with that much juice.
sickofsoyo
DO WORK SON!
sickofsoyo
Roxbury, NJ
sickofsoyo
