Wiring Help?
Originally posted by flatlandin_man2 I have 2 12" dual 2ohm subs. I want to run them off of my 4 channel 400 watt amp. I was wondering what the best way to hook them up would be? Any help will be greatly apreciated, thanxz.
What kind of amplifier. 2 ohm stable? Bridgeable?
Ok you have 4 voice coils. You could run a voice coil to each channel. 4 coils, 4 channels.
Can you bridge the amplifier? If so you could then wire the VC in series to make each sub a 4 ohm load. The bridge the amplifier on each sub. If it were mine I would do that.
you should bridge the amp into two channels, then put one woofer with its voice coils in parallel on each of the channels, this way you will be running both subwoofers at 2 ohms each and get maximum power. Warning, make sure the amp is 2 ohm stable in bridged mode, because just because its stable unbridged , doesnt mean its stable bridged at 2 ohms
Thanks for the input. Much appreciated. The dsp is an afterthought. I haven't installed anything yet but I put a budget system together. I already...
533
In a case like In a case like yours I would rather recommend tactile transducers. They are like woofers without the cone section that are...
930
Your image doesn't really show anything. That could be 3 different head units for all we know, but I think it's 2 different add-ons. It sounds...
978
Try again on the attachments/pictures. They didn't load. Not exactly sure on the wiring, but you can buy an adapter harness that goes from your...
flatlandin_man2
AJ
flatlandin_man2
Lewistown, PA
lamontjersey
    May 18, 2024
    May 16, 2024
