wiring help!
soul05
cookies or death??
im completely noob to this, but i wired my car yesterday. i unhooked the neg terminal first and then proceeded with hooking up the positive terminal to a fuse i bought with my 4 gauge knukonceptz amp kit. then i ran that wire through my firewall and into my car. it ended up in my trunk, where my amp is located. then i ran my signal cables from my head unit through the other side of my car, including the remote turn on wire. it then ended up in my trunk. then i plugged the positive terminal into my amp, i plugged in the ground and connected it to a bolt next to my spare tire. then i plugged in my cables from my hu, and my remote turn on cables. turned on my car to see if i would get power...and wooo...no power. is there something that i am doing wrong?
hmm.. check to make sure your fuse is good,and check your connections. make sure everything is good and secure, and that your ground is on BARE metal. is everything brand new? or did you buy it used? if you bought it used, you may have bought a smoked amp.
what is your setup?
sub(s), amp, h/u? how are your subs wired to the amp?
everything i bought was brand new. i checked the power cable many times, as well as the ground cable.
my setup is an idq12, profile ap1000m and an alpine hu. ive tried grounding it to several different locations within my trunk, and it was still no good.
its probably your remote turn on wire.....if you have it hooked up to your headunits remote wire--blue or blue/white i think--, try unhooking from your headunit and connect it to the same wire --red i think--that your headunit's ignition controlled source is wired to.
take a little piece of speaker wire and run it from the 12v terminal on the amp to the remote terminal, if it comes on, its your remote wire thats bad/disconected somewhere
you got it hooked up to a constant source....you need to hook your blue remote wire from the amps to an ignition controlled source.....like the red wire behind your headunit... if you just used a little jumper from your amp power wire to the remote terminal on the amp then you need to take that off.
soul05
cookies or death??
soul05
San Francisco
soul05
Mike Mccabe
