Wiring Help! Sub / Amp install
schilla46
Hello!
I am trying to wire up my new car audio in my car, I am retaining the stock control centre for the vehicle, so I am not adding or changing the vehicles head unit.
I have a Sony 4 Ch 600 watt amp (xm-gtx6040) that I'm going to splice into the front / rear speakers with a high / low lever converter, to run the front & rear speakers from the amp. Also am I better off using the high / low converter or going straight into the amps high level input plug?
As the sub has it's own amp, can I splice into either the front or rear speakers as well? (So running the high / low converter to the rear speakers + directly to the sub as well?)
It's a kicker hideaway (active sub), it has it's own amp inbuilt - it's designed to go in small cars under seats. KICKER | Hideaway Powered Subwoofer
Cheers
schilla46
schilla46
Australia
schilla46
