This is the back of the Pioneer AVH-P4100DVD headunit I have,..
http://www.pioneerelectronics.com/StaticFiles/PUSA/Images/AVH-P4100DVD_rear_lrg.jpg
It's hard to make out.. but I believe on the left RCA outs are Front, Rear, and Sub. So those are the ones I'll be running 3 separate RCA cables for.
I will be starting with just front components a sub, and Amp to run them all.
Few questions.
1) Can I go ahead and run the Rear (Rear output from Headunit) [Along with the Front RCA's and Sub RCA's that WILL be hooked into amp] RCA cable back to the amp area (but leave it unhooked from amp).. so in the future when I may put in rear 6.5" speakers it makes the job a lot easier? Or will running RCA's from headunit , and not hooked into amp cause some sort of noise in the system?
2) Currently the factory speakers are wired into the headunit.. Do I have to "unwire" anything on the back of the headunit? Or can I Just run the RCA's.. and tap into the blue remote wire.. and run RCA's and remote to amp.. then I'll be running new Speaker wire from amp to new speakers, of course the old wiring will be left unhooked. -- Again will this create any issues? Or do I need to cut wires on the back of the headunit where it feeds the old speaker wire?
I would logically think the headunit would pick up the RCA's being used by the amp and somehow turn "off" it's output to the normal "old" speaker wires I'll simply be unhooking? This so?
And just curious about wire spacing.
Can power wire and your speaker wire be next to each other. Because I'm sort of running out of space designing this in my head.. I was thinking to run RCA's down middle console,.. Run power wire down passenger side (and the passenger side speaker wire to that speaker next to it). Then run the Driver side speaker wire down the driver side edge (this would of course just be the speaker wire as the Power cable will be down the passenger side.)
This a typical way to run your wiring?
Thanks guys,
Few questions.
Thanks guys,
