Wiring Comps
it does 125 x 2 @ 4 ohms? then just hook the components up... and it'll be 4 ohms... unless you have some weird speakers...
Amp does like 250 @ 2ohms
125 @ 4
how would i wire them up for a 4 ohm load. My speakers are 4 ohms
XXX is still in Original Box in my basement //content.invisioncic.com/y282845/emoticons/hilarious.gif.02a037aad04aa96f19982b298a3d70a8.gif
im thinking about changing the design. ( Again )
If i get the volume of the box, how do i calculate the port?
Phoenix Gold R4.0:2
Specification
2 channel power amplifier
12dB HP/LP FIXED crossovers
Full range aux output
Dimensions: 11.75L x 10.875W x 2.25H
125W x 2 (4 ohm stereo)
400W x 1(4 ohm Bridged)
So you say just hook them up and i'll get a 4ohm load?
I wont be running 2 omhs to them, but if i wanted 2 ohms... how would the wiring be different?
How exactly would i wire all this up?
My Car has a 10 speaker system with amp in the back.
im only gonna run comps upfront.
im using my stock wiring.
2 Channel Amp and AudioControl EQX, Stock HU
Does my Wiring sound right?
From my Stock Amp Harness:
1) Connect Woofer & Tweeter to my new Diamond xover.
2) From my New Amp Connect the L/R front inputs to the amp and connect them to the high level input plug on the EQX
3) Run a short RCA to new amp and then run the the output of your new amp to the input of the diamond crossovers
plazman
plazman
USA
plazman
