plazman 10+ year member CarAudio.com Elite 660 0 USA Sep 23, 2004 #1 i know how to wire subs to a certain ohm load, but how would i do that for my comps? My amp does 125@4 ohms... JL and fosgate have great diagrams for wiring subs, but none for speakers. Click to read more...
S Slody4Futbol 10+ year member CarAudio.com Elite 1,206 0 Jackson, MS Sep 23, 2004 #2 it does 125 x 2 @ 4 ohms? then just hook the components up... and it'll be 4 ohms... unless you have some weird speakers...
BASS OUTLAW 10+ year member Single sub fan 1,084 6 next street Sep 23, 2004 #3 where did your XXX go ??
OP plazman 10+ year member CarAudio.com Elite 660 0 USA Sep 23, 2004 Thread Starter #4 it does 125 x 2 @ 4 ohms? then just hook the components up... and it'll be 4 ohms... unless you have some weird speakers... Click to expand... Amp does like 250 @ 2ohms 125 @ 4 how would i wire them up for a 4 ohm load. My speakers are 4 ohms XXX is still in Original Box in my basement //content.invisioncic.com/y282845/emoticons/hilarious.gif.02a037aad04aa96f19982b298a3d70a8.gif im thinking about changing the design. ( Again ) If i get the volume of the box, how do i calculate the port?
DBfan187 5,000+ posts Supa's mom was here! 52,741 236 Poolside with Supa's mom. Sep 23, 2004 #5 JL and fosgate have great diagrams for wiring subs, but none for speakers. Click to expand... same concept
S Slody4Futbol 10+ year member CarAudio.com Elite 1,206 0 Jackson, MS Sep 23, 2004 #6 is it 125 x 2 or 125 x 1? if it's a mono amp that's usually for sub only...
johnecon2001 5,000+ posts SSA/ROE Super-Møderator 5,321 60 Phoenix, AZ Sep 23, 2004 #7 since the speakers run at four ohms, all you have to do is hook them to the amp, and the amp will read the 4 ohm resistance and run at four ohms.
S squeak9798 5,000+ posts Banned 26,540 97 USA Sep 23, 2004 #8 Yeah.......what amp do you have?? I hope you don't have a mono amp
OP plazman 10+ year member CarAudio.com Elite 660 0 USA Sep 24, 2004 Thread Starter #9 Phoenix Gold R4.0:2 Specification 2 channel power amplifier 12dB HP/LP FIXED crossovers Full range aux output Dimensions: 11.75L x 10.875W x 2.25H 125W x 2 (4 ohm stereo) 400W x 1(4 ohm Bridged) So you say just hook them up and i'll get a 4ohm load? I wont be running 2 omhs to them, but if i wanted 2 ohms... how would the wiring be different?
S Slody4Futbol 10+ year member CarAudio.com Elite 1,206 0 Jackson, MS Sep 24, 2004 #10 just hook one set of comps to each channel... that will be 125 x 2
OP plazman 10+ year member CarAudio.com Elite 660 0 USA Sep 24, 2004 Thread Starter #11 How exactly would i wire all this up? My Car has a 10 speaker system with amp in the back. im only gonna run comps upfront. im using my stock wiring. 2 Channel Amp and AudioControl EQX, Stock HU Does my Wiring sound right? From my Stock Amp Harness: 1) Connect Woofer & Tweeter to my new Diamond xover. 2) From my New Amp Connect the L/R front inputs to the amp and connect them to the high level input plug on the EQX 3) Run a short RCA to new amp and then run the the output of your new amp to the input of the diamond crossovers
