R rac_1974 10+ year member Junior Member 17 0 L.V. Nov 6, 2002 #1 I have an amp(4 ch) and is bridged to 2 12's that are svc in a dual bandpass box. How can I get more power(dB's) to pound harder with what I got? The 12's are Legacy(500 watts each) and the amp is a Pyramid amp(1800 watts). Click to read more...
S Steven 10+ year member Member 118 0 CNP Nov 6, 2002 #2 Replace the amp. Pyramid makes ok subs and speakers but their amps are VERY noisy. Other than that you can't increase the power output. If you turned your gains up to max to try and get more power check out http://caraudio.sytes.net/ Go to the amplifier section
S Steven 10+ year member Member 118 0 CNP Nov 6, 2002 #3 Replace the amp. Pyramid makes ok subs and speakers but their amps are VERY noisy. Other than that you can't increase the power output. If you turned your gains up to max to try and get more power check out http://caraudio.sytes.net/ Go to the amplifier section
OP R rac_1974 10+ year member Junior Member 17 0 L.V. Nov 6, 2002 Thread Starter #4 Originally posted by Steven Replace the amp. Pyramid makes ok subs and speakers but their amps are VERY noisy. Other than that you can't increase the power output. If you turned your gains up to max to try and get more power check out http://caraudio.sytes.net/ Go to the amplifier section Click to expand... Thanks for your comment. I'll try something different.
