Wiring a Pioneer Carrozzeria DEH-P01 and amp
jmc0369
CarAudio.com Regular
I have a said head unit and amp, going into a 2003 Ford F250.
The harness from the head unit has a fused clear wire with yelow stripe. I am assuming this would go to a source for accessory power?
Where would these go?
Red wire=?
Orange/White stripe =?
Black = Ground
System remote control (Blue)
These two can be left unconnected, correct?
antenna control (blue/white)
There are also tagged lines for mute (yellow/black)
Coming out the back of the amp I have a 12 ga yellow wire. 12v accessory source?
Grounds and
Blue/white that looks like it was never attached. Where would that go?
You need to Google up, and or research the wiring diagram for that HU. To me.. its sounds like you do not need to be behind the dash. Find a Local shop to put it in for you or take a 50/50 shot at it yourself with some kind of wiring diagram.
That clear wire must be some accessory specifically for that head unit. Best to try to find a manual online or just email Pioneer to confirm everything else is standard color coding.
jmc0369
jmc0369
socal
hispls
