Wiring a 4ohm amp and 4ohm sub
Since that amp isn't 2ohm bridged stable your kinda outta luck as far as power goes, the sub is only gonna be seeing 250. You will jus thave to wire each voicecoil to a separate channel. Also i may be mistaken, but if you wired your sub like that to your amp im pretty sure you would blow the thing(amp) to hell. Not positive though, just wouldn't recomend it.
http://forums.caraudio.com/vb/showthread.php?t=31984
GDut0n
GDut0n
minnesota
nosaj070
ThxOne
    May 13, 2026
ThxOne
    May 13, 2026
