Wiring 1 sub with 4 channel amp
DetoxLS
I am going to put one DVC sub in my car with the open 2 channels on the amp. I have the amp powering the front speakers. My amp runs at 65x4@4ohms and 85x@2ohms.
To get 170 watts from the amp would I get a 2ohm x 2 DVC or a 4ohm x2 DVC? When connecting to the amp, do I use the Positive from the first channel and negative from the secong channel?
I am going to put one DVC sub in my car with the open 2 channels on the amp. I have the amp powering the front speakers. My amp runs at 65x4@4ohms and 85x@2ohms.To get 170 watts from the amp would I get a 2ohm x 2 DVC or a 4ohm x2 DVC? When connecting to the amp, do I use the Positive from the first channel and negative from the secong channel?
Get either a dual 2ohm sub or a single 4 ohm sub. Follow the directions on the amp on how to bridge the 2 channels.. Check out the sticky for more information on wiring.
If you have a dual 2 ohm driver you can have a final impedance of 1ohm or 4ohms
Because you're using esentialy a 2 channel amp(two channels on a 4 channel amp....I did understand that correctly? I think u r using a 4 channel amp, 2 of those channels are being used for front mids/tweets? and the other 2 channels for your sub? Is that right?
DetoxLS
DetoxLS
South FL
pks71
