wire subs right?
ajm
I just got done hooking up my stuff and something hit me about weather I hooked up my subs right. Im running 3 l7's in series (pic below), but heres where im wondering if I messed up. For the little wire that connects one + and one - terminal on the sub on all 3 I hooked the negative w/ the dot and the pos. with the dot together. Is this correct or do/did I need to hook it up to where one of the pos/negative terminals had a dot and the other pos/negative terminal doesnt have a dot?
Heres how I have it wired up..The little dots drawn in paint represent the terminal (+ or -) with the white dot on them.
That is wrong. The 2 terminals with the dots are one voice coil and the two with out the dots are the other.
So you pretty much just connected the one voice coil together.
If you move your black terminal w/ the dot to the bottom black terminal you'll be ok.
ajm
ajm
N/A
jrz126
