Wire in series or parallel
  • 4
Ok so I have 2 jlaudio 4” c2and 2 jbl 4x6 And I recently just got a RF P200.2 ampI. have been looking buy can’t seem to find an answer on how I should wire them for the 2 channel amp the JL Audio 4imch “c2are in the front and the 4x6 are in the rear . The ohm load on the 4x6 is 4 and 4 on the 4” Thanks in advance for your help and have a great day
Two speakers parallel per channelIf u run that sucker in series itll prob put out less than the headunit
Also that’s left and right speakers mot front and back correct ? Even tho the speakers are different ? And one more thing can I just connect both positive and - From the head unit And run one wire back to the amp and the same on the other side ? or should I run 2 separate wites from th head unit for each speaker for
Such smallish speakers tho. I would worry about the front vs. the back since that's where your sound comes from. What vehicle are we talking about here?
It’s in a 1997 Isuzu rodeo the 4x6 are in the rear roof and the 4” are in the doors I wish I would have opened the door b4 buying speakers ! There is soo much room in there but oh well next times! I
Ok soo hook both fronts in parallels and both rear in parables but plug into ine into right channel and one into left ?
Yes. Or preferably get a 4 channel and do it right. I think dual and pioneer have some decent ones for under 100. Are you using factory speakers or aftermarket? And are u using rca's or speaker level inputs?
Also what crossover setting hifi ? Or all pass or mono thanks again for all your help
This is what I ordered from Amazon. https://www.amazon.com/gp/product/B07MXMPHKS/?tag=caraudiocom-20...
264
the AVIC was a tad more complicated to wire not to mention stuffing it in a smallish stereo hole. thanks for advice.
758
Drill a hole and use the proper protective split loom and hole grommets to keep the outer speaker jacket from knicks and cuts, give just enough...
951
It mostly comes down to weight. You can have a super lightweight cone, soft suspension and aluminum coil on a sub and you pretty much get a pro...
942
Partie4evr
Partie4evr
Santa Barbara ca
Partie4evr
    May 31, 2024
    May 24, 2024
