winisd problem
wilzyx
village idiot/racist
i was messin around in winisd alpha to figure out what box size, port area, etc i should use for a RE SE 12. i went to the RE websiteand typed in all the parameters, but when i went to save it, it said there were conflicting problems with qts, qms, and qes. i double checked everything numerous times and it was all correct. is winisd retarted or is RE's site wrong?
i hd the same thing happen to me, so i gave up. my 12" se is in a 1.0 cu ft sealed box right now and its lacking everything but low end bass. im wanting high and low end bass for all my metal/hardcore music and some rap. im awaiting on moe lester to get back to me w/ a design for a 2.5 cu ft ported around 32hz, hopefully itll bring out all the high and low end bass i need.
just change one of the things to a blank answer then click on a diff box so that it configs itself then it will work
also there a patch out for all the re subs ill look for it
are there any more patches cuz i wanna mess around with the kicker compvr's also and they arent in there and i would rather not have to type in all the parameters and crap
wilzyx
wilzyx
Des Moines, Iowa
wilzyx
