Winisd Pro Question
Spddracer
Sounds Goooooood
When you put the series res. in winisdpro is it supposed to be .2 ohm or 2 ohm for a 2 ohm series resitance ?? Are you to put the decimal point in or not ?? if i dont i have a huge peak if I do it is a nice flat curve ???
Originally posted by Spddracer When you put the series res. in winisdpro is it supposed to be .2 ohm or 2 ohm for a 2 ohm series resitance ?? Are you to put the decimal point in or not ?? if i dont i have a huge peak if I do it is a nice flat curve ???
no decimal point. the HUGE peak would be because ur amp would be running at a .2ohm load....which most will not even consider handling
Originally posted by Alaxan no decimal point. the HUGE peak would be because ur amp would be running at a .2ohm load....which most will not even consider handling
I thought that in winisd pro , That the seires resitance would be the resistance in the line like.1 ?? Doesnt winisd already know the ohm load of the driver ??
Spddracer
Sounds Goooooood
Spddracer
Ohio
Spddracer
ThxOne
    May 13, 2026
ThxOne
    May 13, 2026
