Winisd Pro Question
  • 2
Spddracer
Sounds Goooooood
1,337
Ohio
When you put the series res. in winisdpro is it supposed to be .2 ohm or 2 ohm for a 2 ohm series resitance ?? Are you to put the decimal point in or not ?? if i dont i have a huge peak if I do it is a nice flat curve ???
Originally posted by Spddracer When you put the series res. in winisdpro is it supposed to be .2 ohm or 2 ohm for a 2 ohm series resitance ?? Are you to put the decimal point in or not ?? if i dont i have a huge peak if I do it is a nice flat curve ???
no decimal point. the HUGE peak would be because ur amp would be running at a .2ohm load....which most will not even consider handling
Originally posted by Alaxan no decimal point. the HUGE peak would be because ur amp would be running at a .2ohm load....which most will not even consider handling
I thought that in winisd pro , That the seires resitance would be the resistance in the line like.1 ?? Doesnt winisd already know the ohm load of the driver ??
You have to know the signs for winisd. IMO, it really comes down to knowing what you’re doing. Some woofers don’t model well in winisd, at all.
$2500usd for all three Shipping and PayPal fees extra I have a few BNIB pro series in stock I'm moving. These 3 listed is a full 3way system...
Nope, Either or. If you own both, then it's a loss on one or the other less what you sell it for, right? The PAC is an easier install and that...
Spddracer
Sounds Goooooood
Spddracer
Ohio
Spddracer
