Will wiring 2 subwoofers with different impedances make one get less power?
BassIsGrace
I ordered a hds2 12(d4) from soundqubed and they sent me a d2.I didn't feel like sending it back and waiting longer so I wired it parallel to the other hds2 12 (d4) and my DMM showed they were resting at .8 ohms. My hifonics amp is 1 ohm stable but this ohm load doesn't make it over heat or act funny.1 person said it doesn't matter if 2 subs are different impedances.they will split the power between the 2.the other person said send it back cause they wont get even power.one will get less and the other more.which is true?
Most likely get uneven power as it has less resitance than the other sub/subs
---------- Post added at 08:16 AM ---------- Previous post was at 08:15 AM ----------
Just my MO
so you can basically think about it like this (if all wiring is parallel).. since you have one woofer at 1ohm and the other woofer at 2ohms, the 1ohm woofer (d2) will see 66% of the total amplifier power and the 2ohm woofer (d4) will see 33% due to common current division.
There are simple circuits equations that calculate your exact(ish) power division for any coil configuration but I would have to explain equivalent resistances, then power calculations, then current division, which I could do if need be. I'm not gonna type it up if nobody cares though. Lolz
probably a dramatic increase if they're in a shared chamber. Since the d2 woofer is seeing twice the power that the other is seeing, it is moving probably close to twice as far from peak to peak. The d4 woofer is just kinda flappin around in there on that lower power and sort of "getting in the way" of the d1. I'm sure there is a fair amount of cancellation going on there.
Yup , the dsp should have input sections, it may have one for sub? Hu to dsp. Dsp to amps, amps to speakers. Probably help you to draw this all...
217
Box rise, more accurately, impedance rise, is the reactive load changes the woofer exhibits at different frequencies and it will happen, it's...
4
454
BassIsGrace
BassIsGrace
Lusby,Maryland
BassIsGrace
slater
    May 2, 2024
slater
    May 2, 2024
Latest topics
