Will this work-its weird
Will it work? Yes
Would it work better with a larger port? Yes
Will you more than likely get port noise? Yes
2" Diameter is not a very large port, at all. Have you considered Aero ports?
Also, what sub? I'm assuming a 12 ported...
Will it work? Yes
no i havnt. see i tried a bigger port but it wasnt at the frequency i wanted it at. i've never considered a aeroport tho.
I'm running a very similar box with a 2.25" port and it sounds fine. There's some port noise, but not enough for me to care.
Although, when I get the new sub I will be going with a larger port.
I'm running a very similar box with a 2.25" port and it sounds fine. There's some port noise, but not enough for me to care. Although, when I get the new sub I will be going with a larger port.
well i hav a pickup truck and the sub will be very close to me so minimum port noise would be nice
My honest advice? Talk to someone around here, and pay the 10 dollars or whatever it is for a design. It will be what you want if you use someone who is somewhat credible. They can also give you the dimensions for either an Aero or classic port.
A lot easier, and only 10 bucks for a lot less trouble to go through.
who will design a box for ten bucks? Im interested in having some plans drawn up. If you read this and can make some plans for a couple of tens, let me know. PM Me
Buck
little alien on campus
Buck
Inside of a pyramid
waterboy
