will this system fit
depends if you are putting them in the trunk or the back seat trunk i highy doubt
but the back sit there should be plenty of room if its built right and depending on how much air space your subs take
i would suggest (for better SQ and SPL) that you stick with the same size subs (don't mix 12's and 15's)! and would also suggest you go with the 3 12's instead of the 15's for better SQ and i dont think you will have to worry about losing out on too much SPL with the 12's in a Tbird. i dont think there is enough room in a Tbird for 2 15's to be able to maximize their output potential. just my opinion, hope it helps!
hello
I agree with imral3. Mixing sub sizes really isnt worth the hassle. Some have said the mixing subs tends to cancel out each other anyway. I would go with 3 12's in your bird. Also powering these will be much easier. You could even go with possibly 4 12's on 2 amplifiers. Don't forget, 12" subs usually need approx. 1.5 cu. feet in a sealed enclosure.(depending on the make) Base reflex enclosures need even more. Good luck!
PIMPTBIRD
PIMPTBIRD
michigan
vargy
TechGuru88
    Aug 10, 2026
TechGuru88
    Aug 10, 2026
