Will this amplifier work.
cjr904
I just got two Audiobahn AW1051Q 10" Subwoofers for free in the mail and am wondering what type of amplifier is best to run to get good bass out of the system without destroying them or if this amp will work fine. The box says they are ,300 watts rms ,dual voice coil, and 2 OHM or 8 OHM operational. frequency response is 30HZ-1KHZ and 91.1dB. I don't know if all that information was necessary but im a beginner so oh well. Thanks in advance for any help.
Will a rockford fosgate R-500-1 Amp putting out 500 watts at 2 ohms work fine?
If the box says they're 2 or 8 ohm operational, and they are dual voice coils, that means that each woofer is a dual 4, which means you can wire it up to 1, 4 or 8 ohms. That 500w alpine probably isn't 1 ohm stable.
it says "rockford fosgate" in the OP. jesus buck.
you need to find a amp that's 1 ohm stable and can put out 500w+.
cjr904
cjr904
Orange Park, FL
SPL Blazer
BP1Fanatic
BP1Fanatic
