Will this amp work better?
Warrior
WI
My current amp is 400x1 @ 4ohms. This one is 800x1 @ 4ohms.
Im thinking about getting it, if i can sell my current amp that is.
ROCKFORD FOSGATE 801S
200 watts RMS x 2 at 4 ohms
400 watts RMS x 2 at 2 ohms
800 watts RMS x 1 bridged output at 4 ohms
stereo or bridged mono output
4-ohm stable in bridged mode
Tri-Way capable
wiring and hardware not included with amplifier — we recommend an 8-gauge amp wiring kit with a 60-amp fuse
50-250 Hz high-pass/low-pass (12 dB/octave) crossovers
MOSFET power supply and output devices
MEHSA mounting technology increases the heat transfer from the MOSFET output devices to the heat sink, for higher power output, lower operating temperatures, and greater reliability
TOPAZ — noise-killing differential inputs that eliminate 80% of ground loop noise
*****•ana circuitry keeps preamp voltages low and signal paths simple for outstanding audio quality
NOMAD — advanced protection circuitry for "intelligent" shutdown protection
wired remote included for fingertip control of Punch Bass (0-18 dB boost at 45 Hz)
speaker- and preamp-level inputs
17-1/16"W x 2-7/16"H x 9-7/8"D
1-year warranty
Anybody wanna buy my amp ? heh. I think this one would work much better. As my current setup is only giving me half of what i need.
My current amp is: 1 Pioneer Premier PRS-X720 Amp 400watt x 1 @ 4ohms
Im powering 2 10" Pioneer Premier 800watt / 400watt RMS speakers. Dual coils, 2ohms or 8 ohms, or bridged to 4 ohms.
Im not making this post to sell my amp, just an suggestion and i wont need this amp if i get this Rockford one...which i think i should?
Well you see i bought it used, it works great but i didnt get the birth sheet. And yeah I know this amp puts out a world average of like 650 watts RMS @ 4ohms x 1.
But it does not sound nearly as good as some of my friends or even my sisters setup with a kicker 400.2 amp and alpine type r 12".
Originally posted by Jmac LOL, look at your birthsheet man ... I have numerous birthsheets showing the PRS-X720 doing in excess of 800 RMS @ 4 ohms mono :p
However, if you want to downgrade to the Rockford, I'll be glad to take it off your hands //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
How much ?
Well when i try to wire it into 4 ohms..., it wont let me put the speaker wire to the + side on the L and the - side on the RIGHT for a bridged 4 ohm load. I have the speakers wired correctly, + from speaker 1 and 2 together, and - from speaker 1 and 2 together, and on each some, + and - together.
I can only hitch it up to the amp from the L + and the R+, otherise just either the R + and - or, the L + and -.
Maybe something is wrong that I am nothing noticing? I did install it myself, so...
Maybe it'd have to go with my ground not begin good enough? not sure...
Warrior
Warrior
WI
mamey69
michigan born
    May 14, 2026
michigan born
    May 14, 2026
